[GRASS-user] v.in.ascii don't work
Michael Barton
michael.barton at asu.edu
Tue May 29 11:34:47 EDT 2007
Emmanuel,
Here are some ideas
Is the region correct? That is, do these coordinates occur in your region
(check extents and resolution using g.region -gp or directly from the menu)?
Are the end of line/carriage return characters correct? You are on a Linux
system which ought to produce the correct ones, but it's worth checking.
Try a different field separator. Try a comma.
Change your column names. Using "nul" and/or "val" could be problematic
Michael
On 5/29/07 2:07 AM, "Poizot Emmanuel" <poizot at cnam.fr> wrote:
> gary a écrit :
>> When I had a similar problem, I ended up using csv file from a
>> spreadsheet as the input file.
>> Otto Dassau wrote:
>>> Hi,
>>> for me (GRASS 6.3cvs) the import of your test data works, the syntax is
>>> correct. Maybe you need to check your test.txt for <space> values in
>>> your
>>> columns etc?
>>> regards,
>>> Otto
>>> On Tue, 29 May 2007 09:31:38 +0200
>>> Poizot Emmanuel <poizot at cnam.fr> wrote:
>>>> Hi all,
>>>> I'm unable to input text file in GRASS using v.in.ascii.
>>>> I'm (trying) working on GRASS 6.2.1 under Ubuntu Fiesty
>>>> I have a text file (test.txt) which containing:
>>>> 1|3.5|43.6|2.3
>>>> 2|3.55|43.605|1.2
>>>> 3|3.51|43.621|-2.3
>>>> 4|3.485|43.704|56.1
>>>> 5|3.498|43.5|7.1058
>>>> I would like to import it in a new layer with the following command:
>>>> cat test.txt | v.in.ascii out=test columns='nul int, x double, y
>>>> double, val double' fs="|" x=2 y=3 z=0
>>>> and the outputs of that command is:
>>>> Maximum input row length: 20
>>>> Maximum number of columns: 4
>>>> Minimum number of columns: 4
>>>> column: 1 type: integer
>>>> column: 2 type: double
>>>> column: 3 type: double
>>>> column: 4 type: double
>>>> Building topology ...
>>>> 0 primitives registered 0 areas built 0 isles built
>>>> Attaching islands:
>>>> Attaching centroids: Topology was built.
>>>> Number of nodes : 0
>>>> Number of primitives: 0
>>>> Number of points : 0
>>>> Number of lines : 0
>>>> Number of boundaries: 0
>>>> Number of centroids : 0
>>>> Number of areas : 0
>>>> Number of isles : 0
>>>> So no points are imported in the layer.
>>>> I turn around that problem wich normally should work, as what I raed
>>>> everywhere, but not for me !!
>>>> Regards
>>>> E. POIZOT
>> grassuser mailing list
>> grassuser at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grassuser
> Hi,
> I check for spaces on columns, misllaneous character, etc. The text file
> is clean.
> I also check the bounadries of my region settings and it's ok, the
> points are inside it.
> I just produced a CSV file from a spreadsheet, and still not work.
> How to know what happend durin v.in.ascii execution (debug or a log file) ?
> Regards
> EP
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
