[GRASS-user] grass 6.3 bug
    Maciej Sieczka
    tutey at o2.pl
    Tue May 29 12:07:34 EDT 2007
Leonardo Lami wrote:
> Hi all,
> I'm testin grass 6.3 and I have a problem with v.dissolve:
> v.dissolve input=t_comuni_2003 at PERMANENT output=province layer=1
> column=provincia
> dbmi: Protocol error
What platform?
What 6.3 CVS checkout date?
What DB backend do you use?
Can you reproduce the problem in sperfish60 location?
If you don't and can't provide your data for testing, run:
$ g.gisenv set="DEBUG=5"
then your v.dissolve command and pass the output over to the list.
You might find this usefull:
http://grass.gdf-hannover.de/wiki/GRASS_Debugging
Maciek
