[GRASS-user] grass 6.3 bug
Leonardo Lami
lami at faunalia.it
Tue May 29 12:24:58 EDT 2007
Maciej Sieczka ha scritto:
> Leonardo Lami wrote:
>> Hi all,
>> I'm testin grass 6.3 and I have a problem with v.dissolve:
>> v.dissolve input=t_comuni_2003 at PERMANENT output=province layer=1
>> column=provincia
>> dbmi: Protocol error
> What platform?
Linux Debian
> What 6.3 CVS checkout date?
26/05/07
> What DB backend do you use?
postgresql 8.1
> Can you reproduce the problem in sperfish60 location?
v.dissolve input=soils at PERMANENT output=soils layer=1 column=label
and the output shell stops
I must make Ctrl-c to go on
now db=dbf
> If you don't and can't provide your data for testing, run:
> $ g.gisenv set="DEBUG=5"
> then your v.dissolve command and pass the output over to the list.
D3/5: dig_isle_alloc_line():
D3/5: dig_Rd_P_isle()
D2/5: Vect_cidx_open(): name = soils mapset= PERMANENT
D3/5: dig_cidx_init()
D3/5: dig_read_cidx()
D3/5: Cidx header: file version 5.0 , supported from GRASS version 5.0
D3/5: byte order 0
D3/5: header size 9
D1/5: V1_open_old_nat(): name = soils mapset = PERMANENT
D2/5: Coor header: file version 5.1 , supported from GRASS version 5.1
D2/5: byte order 0
D2/5: header size 14
D2/5: with_z 0
D2/5: coor size 634133
D1/5: get coor info:
/home/Documenti/datigrass/spearfish60/PERMANENT/vector/soils/coor
D1/5: Info->size = 634133, Info->mtime = 1113222409
D1/5: coor size in head = 634133, real coor file size= 634133
D2/5: dig_file_load ()
D2/5: requested mode = 2
D2/5: size = 634133
D2/5: file was not loaded to the memory
D1/5: Vect_open_old(): vector opened on level 2
D1/5: Vect_read_dblinks(): map = soils, mapset = PERMANENT
D3/5: Searching for FID column in OGR DB
D1/5: dbln file:
/home/Documenti/datigrass/spearfish60/PERMANENT/vector/soils/dbln
D1/5: dbln: 1 soils cat $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/ dbf
D3/5: Field number <1>, name <(null)>
D3/5: Vect_check_dblink: field 1
D1/5: field = 1 name = (null), table = soils, key = cat, database =
$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/, driver = dbf
D1/5: Dblinks read
D1/5: Vect_Rewind(): name = soils
D2/5: Vect_open_new(): name = soils at PERMANENT_7790
D1/5: Vect_set_thresh(): thresh = 0.000000
D1/5: V1_open_new_nat(): name = soils at PERMANENT_7790
D1/5: Vect_get_thresh(): thresh = 0.000000
D1/5: dig__write_head()
D1/5: write coor size (0) to head
D2/5: coor body offset 14
D3/5: dig_init_plus()
D1/5: dig_spidx_init()
D3/5: Vect_hist_copy()
D5/5: Vect_hist_write()
D3/5: Vect_hist_command()
D3/5: G_recreate_command()
D1/5: Vect_get_field(): field = 1
D1/5: Vect_get_dblink(): link = 0
D3/5: Vect_subst_var(): in = $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/, map
D3/5: -> /home/Documenti/datigrass/spearfish60/PERMANENT/dbf/
D3/5: db_start_driver_open_database():
drvname = dbf, dbname =
D2/5: opendir /usr/local/grass-6.3.cvs/driver/db/
D2/5: DBF: db__driver_open_database() name =
'/home/Documenti/datigrass/spearfish60/PERMANENT/dbf/'
D2/5: db.name = /home/Documenti/datigrass/spearfish60/PERMANENT/dbf/
D2/5: add_table(): table = archsites name = archsites.dbf
D2/5: add_table(): table = bugsites name = bugsites.dbf
D2/5: add_table(): table = fields name = fields.dbf
D2/5: add_table(): table = roads name = roads.dbf
D2/5: add_table(): table = soils name = soils.dbf
D2/5: add_table(): table = streams name = streams.dbf
D2/5: find_table(): table = soils
D2/5: ? archsites
D2/5: ? bugsites
D2/5: ? fields
D2/5: ? roads
D2/5: ? soils
D2/5: load_table_head(): tab = 4,
/home/Documenti/datigrass/spearfish60/PERMANENT/dbf//soils.dbf
D2/5: ncols = 2
D2/5: DBFFieldType 1
D3/5: add_column(): tab = 4, type = 2, name = cat, width = 11, decimals = 0
D2/5: DBFFieldType 0
D3/5: add_column(): tab = 4, type = 1, name = label, width = 13,
decimals = 0
D1/5: Vect_default_field_info(): map = soils at PERMANENT_7790 field = 1
D2/5: drv = dbf db = $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
D1/5: Vect_write_dblinks(): map = soils at PERMANENT_7790, mapset = corso
D1/5: dbln file:
/home/Documenti/datigrass/spearfish60/corso/vector/soils at PERMANENT_7790/dbln
D1/5: 1 soils at PERMANENT_7790 cat $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/ dbf
D1/5: Dblinks written
D3/5: -> /home/Documenti/datigrass/spearfish60/corso/dbf/
drvname = dbf, dbname = /home/Documenti/datigrass/spearfish60/corso/dbf/
'/home/Documenti/datigrass/spearfish60/corso/dbf/'
D2/5: db.name = /home/Documenti/datigrass/spearfish60/corso/dbf/
D3/5: SQL: SELECT cat, label FROM soils ORDER BY label
D3/5: SQL statement parsed successfully: SELECT cat, label FROM soils
ORDER BY label
D2/5: ? archsites
D2/5: ? bugsites
D2/5: ? fields
D2/5: ? roads
D2/5: ? soils
D3/5: Doing SQL command <4> on DBF table... (see include/sqlp.h)
D2/5: SELECT
D2/5: sel(): tab = 4
D2/5: load_table(): tab = 4
D2/5: ncols = 2 nrows = 54
D3/5: Order selection by label
D3/5: 54 rows selected
D3/5: key type = 15
D1/5: Vect_close(): name = soils at PERMANENT_7790, mapset = corso, format
= 0, level = 1
D1/5: close history file
D1/5: V1_close_nat(): name = soils at PERMANENT_7790 mapset= corso
/home/Documenti/datigrass/spearfish60/corso/vector/soils at PERMANENT_7790/coor
D1/5: Info->size = 14, Info->mtime = 1180455741
D1/5: write coor size (14) to head
D1/5: dbln file:
D2/5: save_table 0
D2/5: save_table 1
D2/5: save_table 2
D2/5: save_table 3
D2/5: save_table 4
D2/5: save_table 5
and it stops
> You might find this usefull:
> http://grass.gdf-hannover.de/wiki/GRASS_Debugging
> Maciek
