[GRASS-user] grass 6.3 bug
Markus Neteler
neteler at itc.it
Tue May 29 12:53:57 EDT 2007
Bug confirmed... Adding "-x" in the first line of v.dissolve shows the error:
v.dissolve input=soils at PERMANENT output=soils layer=1 column=label
+ table=soils
+ '[' -z soils ']'
+ v.reclass input=soils at PERMANENT output=soils at PERMANENT_23874 layer=1
column=label
dbmi: Protocol error
ERROR: Cannot open select cursor: SELECT cat, label FROM soils ORDER BY
label
It appears that the DBF driver doesn't support correctly "ORDER BY". Too
bad.
Trying dry run in PERMANENT:
echo "SELECT cat, label FROM soils ORDER BY label" | db.select
D3/3: Order selection by label
At this point also PG and SQLite and MySQL will fail, since the originating
file is DBF and hence "ORDER BY" fails.
I am a bit surprised at this point since I dissolved maps recently.
Markus
Leonardo Lami wrote:
>> Can you reproduce the problem in sperfish60 location?
> and the output shell stops
> I must make Ctrl-c to go on
View this message in context: http://www.nabble.com/grass-6.3-bug-tf3834643.html#a10858069
Sent from the Grass - Users mailing list archive at Nabble.com.
