[GRASS-user] grass 6.3 bug
Maciej Sieczka tutey at o2.pl
Tue May 29 13:05:04 EDT 2007
Leonardo Lami wrote:
> Maciej Sieczka ha scritto:
>> What platform?
> Linux Debian
>> What 6.3 CVS checkout date?
> 26/05/07
>> What DB backend do you use?
> postgresql 8.1
>From further reading of Leonardo's post it shows that dbf fails too.
>> Can you reproduce the problem in sperfish60 location?
> v.dissolve input=soils at PERMANENT output=soils layer=1 column=label
> dbmi: Protocol error
> and the output shell stops
> I must make Ctrl-c to go on
I confirm with current 6.3 CVS on my linux box, using dbf driver.
Hopefully Hamish can come up with solution.
Maciek
