[GRASS-user] Grass 6.2 crashes fedora 6
Travis Kirstine
traviskirstine at gmail.com
Tue May 29 16:59:20 EDT 2007
Manuel,
I am running:
Linux version 2.6.20-1.2948.fc6
Markus,
I believe this is the problem you are referring to, the gis.m will
start for a few seconds then disappears after "entering grass". I
will give 6.2.2 a try.
Thanks
Travis
On 29/05/07, Markus Neteler <neteler at itc.it> wrote:
> Travis,
> could you define "crashes"?
> BTW: 5 minutes ago I have packaged GRASS 6.2.2RC1 which probably
> cures potential gis.m problems (I suspect that you refer to this).
> Markus
> Travis Kirstine wrote:
> > Hi all,
> > I am running fedora core 6 and am having some difficulties running
> > grass 6.2. I am able to create a location and mapset using EPSG
> > codes, however as soon as I "Enter Grass" the application crashes.
> > Any ideas or workarounds.
> > Travis K.
> > Toronto, Canada
> > "She knows there's no success like failure
> > And that failure's no success at all."
> > -Bob Dylan-
> View this message in context: http://www.nabble.com/Grass-6.2-crashes-fedora-6-tf3828599.html#a10860962
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Travis K.
Toronto, Canada
-Bob Dylan-
