[GRASS-user] Grass 6.2 crashes fedora 6
Travis Kirstine traviskirstine at gmail.com
Wed May 30 15:28:51 EDT 2007
Sorry to bother you again, I tried the grass6.2.2 cvs update but am
still having the same issues (see below).  I thought it could be a
permission issue but changing the permission didn't fix the problem.
Any thoughts.
Travis
Starting GRASS ...
/usr/local/grass6.2.2cvs-x86_64-unknown-linux-gnu-26_05_2007/etc/Init.sh:
line 319: /usr/local/grass6.2.2cvs-x86_64-unknown-linux-gnu-26_05_2007/etc/clean_temp:
cannot execute binary file
line 567: /usr/local/grass6.2.2cvs-x86_64-unknown-linux-gnu-26_05_2007/bin/g.gisenv:
line 568: /usr/local/grass6.2.2cvs-x86_64-unknown-linux-gnu-26_05_2007/bin/g.gisenv:
line 569: /usr/local/grass6.2.2cvs-x86_64-unknown-linux-gnu-26_05_2007/bin/g.gisenv:
line 575: /usr/local/grass6.2.2cvs-x86_64-unknown-linux-gnu-26_05_2007/etc/lock:
Unable to properly access ///.gislock
Please notify system personel.
On 29/05/07, Travis Kirstine <traviskirstine at gmail.com> wrote:
> Manuel,
> I am running:
> Linux version 2.6.20-1.2948.fc6
> Markus,
> I believe this is the problem you are referring to, the gis.m will
> start for a few seconds then disappears after "entering grass".  I
> will give 6.2.2 a try.
> Thanks
> Travis
> On 29/05/07, Markus Neteler <neteler at itc.it> wrote:
> > Travis,
> > could you define "crashes"?
> > BTW: 5 minutes ago I have packaged GRASS 6.2.2RC1 which probably
> > cures potential gis.m problems (I suspect that you refer to this).
> > Markus
> > Travis Kirstine wrote:
> > > Hi all,
> > > I am running fedora core 6 and am having some difficulties running
> > > grass 6.2.  I am able to create a location and mapset using EPSG
> > > codes, however as soon as I "Enter Grass" the application crashes.
> > > Any ideas or workarounds.
> > > Travis K.
> > > Toronto, Canada
> > > "She knows there's no success like failure
> > > And that failure's no success at all."
> > > -Bob Dylan-
> > View this message in context: http://www.nabble.com/Grass-6.2-crashes-fedora-6-tf3828599.html#a10860962
> > Sent from the Grass - Users mailing list archive at Nabble.com.
> > grassuser mailing list
> > grassuser at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grassuser
> Travis K.
> Toronto, Canada
> -Bob Dylan-
Travis K.
Toronto, Canada
-Bob Dylan-
