[GRASS-user] Error in d.vect.chart
Morten Sickel
Morten.Sickel at nrpa.no
Thu May 31 10:46:26 EDT 2007
Just a couple of follow-ups:
I am using 6.2.1 on cygwin / win XP
When plotting, using
d.vect.chart fisk ctype=bar columns=F1992 size=10 scale=1.5
color=yellow
it looks fine, until I zoom or issue a d.redraw or a d.out.png.
but, if I add a max_ref:
d.vect.chart fisk ctype=bar columns=F1992 size=20 max_ref=40 scale=10
color=yellow
it works fine all the time...
I can do some more investigation, but I do not have time at the moment.
Morten
-----Original Message-----
[mailto:grassuser-bounces at grass.itc.it] On Behalf Of Morten Sickel
Sent: Thursday, May 31, 2007 3:46 PM
To: grassuser at grass.itc.it
Subject: [GRASS-user] Error in d.vect.chart
I am using d.vect.chart to plot some bars to indicate a level. But, the
lines on the right and left sides of the bars extends all the way down
to the bottom of the map... (www.radioecology.info/images/Fisk1992.png)
As a quick work around, is it anyhow possible to avoid having an
outline, or to have a transparent outline?
Morten Sickel
Norwegian Radiation Protection Authority
grassuser mailing list
http://grass.itc.it/mailman/listinfo/grassuser
