[GRASS-user] Error in d.vect.chart
Dylan Beaudette
dylan.beaudette at gmail.com
Thu May 31 12:50:32 EDT 2007
Hi Morten,
I added the max_ref flag, but have not experienced your problems. I am working
with the CVS version however. Can you post some of the particulars about the
data that you are plotting?
cheers,
dylan
On Thursday 31 May 2007 07:46, Morten Sickel wrote:
> Just a couple of follow-ups:
> I am using 6.2.1 on cygwin / win XP
> When plotting, using
> d.vect.chart fisk ctype=bar columns=F1992 size=10 scale=1.5
> color=yellow
> it looks fine, until I zoom or issue a d.redraw or a d.out.png.
> but, if I add a max_ref:
> d.vect.chart fisk ctype=bar columns=F1992 size=20 max_ref=40 scale=10
> color=yellow
> it works fine all the time...
> I can do some more investigation, but I do not have time at the moment.
> Morten
> -----Original Message-----
> From: grassuser-bounces at grass.itc.it
> [mailto:grassuser-bounces at grass.itc.it] On Behalf Of Morten Sickel
> Sent: Thursday, May 31, 2007 3:46 PM
> To: grassuser at grass.itc.it
> Subject: [GRASS-user] Error in d.vect.chart
> Hi,
> I am using d.vect.chart to plot some bars to indicate a level. But, the
> lines on the right and left sides of the bars extends all the way down
> to the bottom of the map... (www.radioecology.info/images/Fisk1992.png)
> As a quick work around, is it anyhow possible to avoid having an
> outline, or to have a transparent outline?
> Morten Sickel
> Norwegian Radiation Protection Authority
> grassuser mailing list
> http://grass.itc.it/mailman/listinfo/grassuser
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
