[GRASS-user] Intersections on World Map
Martin Bley
martin.bley at FernUni-Hagen.de
Thu Nov 1 11:11:10 EDT 2007
I still get stucked on an issue using v.overlay. I imported
a shapefile
with the world continents (the one from ESRI). Projection
is Lat-Long.
Then I draw a line using v.in.ascii representing a latitude
e.g.
VERTI
L 2 1
-180 -80
180 -80
1 1
Now I use the following command to merge the intersection
between the
latitude (80 South) and the areas in the world continents
vector.
v.overlay ainput=$vector atype=line alayer=1 binput=World
btype=area \
blayer=1 output=$out operator=and
Works pretty well so far, until I reach latitude South 75+.
Intersections doesn't
match continents anymore (please see attached PNG file).
I would appreciate any hint.
Regards,
Martin
Martin Bley
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20071101/f4f2f9df/map.png
