[GRASS-user] Using v.in.ascii and v.to.rast in similar fashion as s.in.ascii and s.to.rast
roberto.antolin at polimi.it roberto.antolin at polimi.it
Thu Nov 1 18:30:02 EDT 2007
Hi all,
docR ha escrito:
> Is there an example to follow that is as simple as the use of s.in.ascii /
> s.to.rast version 5.x?
Did you try r.in.xyz? It allows you to create a raster map from an
ascii file and also permits you to set the method, that is: max, min,
mean, stdev, etc...
Saludos,
Roberto.
