[GRASS-user] Intersections on World Map
Martin Bley
martin.bley at FernUni-Hagen.de
Fri Nov 2 12:33:16 EDT 2007
Hi Ivan,
thanks for your answer
On Fri, Nov 02, 2007 at 12:51:50PM +0100, ivan marchesini wrote:
> hmmm
> really strange...
> did you verify the topology of the world map?
> v.build map=$map
GRASS 6.0.2 (World):~ > v.build map=World
Building topology ...
4010 primitives registered
Building areas: 100%
1983 areas built
1953 isles built
Attaching islands: 100%
Attaching centroids: 100%
Topology was built.
Number of nodes : 3980
Number of primitives: 4010
Number of points : 0
Number of lines : 0
Number of boundaries: 2042
Number of centroids : 1968
Number of areas : 1983
Number of isles : 1953
Number of areas without centroid : 15
don't know what to do with this information. What about the 15 "areas
without centroid"?
I just started a new v.overlay operation after building ithe topology
using v.build - same effect.
Thanks,
Martin
Martin Bley
