[GRASS-user] vector map
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Sat Nov 3 05:08:55 EDT 2007
Hi!
If you want to load a raster as a background (for example) do:
1. d.mon x? (with this you start an "x"-monitor --- Where ? substitute with
a number 0,1,2,3,...)
2. Load a specific raster with d.rast "name-of-raster-file"
3. Use v.digit now and run the "digitising" dialog.
Shouldn't be so difficult as it looks like.
In any case, it is recommended, from my small experience, to read the help
for the respective command you want yo use (e.g. man v.digit).
ivan marchesini wrote:
> Hi Isabel
> too few informations...
> which grass are you using?
> with which OS?
> did you try to type "v.digit&" on the shell?
> this usually calls the v.digit gui...
> bye
> Il giorno gio, 01/11/2007 alle 11.31 -0400, Isabel Alfaro Cardozo ha
> scritto:
>> Hi, im new in grass and im trying to create a vector map from scratch
>> and/or with a raster as background, but i cant get the gui of v.digit
>> to work... how does it work?..
>> thank you !!
>> grassuser mailing list
>> grassuser at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grassuser
> Ti prego di cercare di non inviarmi files .doc, .xls, .ppt, .dwg.
> Preferisco formati liberi.
> Please try to avoid to send me .doc, .xls, .ppt, .dwg files.
> I prefer free formats.
> http://it.wikipedia.org/wiki/Formato_aperto
> http://en.wikipedia.org/wiki/Open_format
> Ivan Marchesini
> Department of Civil and Environmental Engineering
> University of Perugia
> Via G. Duranti 93/a
> 06125
> Perugia (Italy)
> Socio fondatore GFOSS "Geospatial Free and Open Source Software"
> http://www.gfoss.it
> e-mail: marchesini at unipg.it
> ivan.marchesini at gmail.com
> tel: +39(0)755853760
> fax (university): +39(0)755853756
> fax (home): +39(0)5782830887
> jabber: geoivan73 at jabber.org
View this message in context: http://www.nabble.com/vector-map-tf4732172.html#a13561095
Sent from the Grass - Users mailing list archive at Nabble.com.
