[GRASS-user] A vector layer
Isabel Alfaro Cardozo isabelalfaro at gmail.com
Thu Nov 1 16:17:49 EDT 2007
What does it mean when it sais
Fallo de segmentación (core dumped)
once I run the v.digit command it makes a new map and then it shows this
mistake   please if some one could help me!..
i also tried to use r.to.vect but  i got this message
r.to.vect
WARNING: coor files of vector 'rasttovect at destimap' is larger than it
         should be (14 bytes excess).
WARNING: Cannot display areas, topology not available
thank you for your help
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20071101/3a6d2e2b/attachment.html
