[GRASS-user] A vector layer
roberto.antolin at polimi.it roberto.antolin at polimi.it
Thu Nov 1 18:24:59 EDT 2007
Hola Isabel and all,
Isabel Alfaro Cardozo ha escrito:
> What does it mean when it sais
> Fallo de segmentación (core dumped)
> once I run the v.digit command it makes a new map and then it shows this
> mistake   please if some one could help me!..
It means that an error occurred while v.digit was running. Usually,
after that error the vector map is not created correctly. That's why
you get those other warnings below.
Maybe, someone in the list could help and you if you explain what you
tried with v.digit.
> i also tried to use r.to.vect but  i got this message
> r.to.vect
> WARNING: coor files of vector 'rasttovect at destimap' is larger than it
>          should be (14 bytes excess).
> WARNING: Cannot display areas, topology not available
Un saludo,
Roberto.
