[GRASS-user] A vector layer
ivan marchesini
marchesini at unipg.it
Fri Nov 2 07:56:26 EDT 2007
ah... ok...
use:
v.build map=mapname
then retry with v.digit over the same map....
Il giorno gio, 01/11/2007 alle 23.24 +0100, roberto.antolin at polimi.it ha
scritto:
> Hola Isabel and all,
> Isabel Alfaro Cardozo ha escrito:
> > What does it mean when it sais
> > Fallo de segmentación (core dumped)
> > once I run the v.digit command it makes a new map and then it shows this
> > mistake please if some one could help me!..
> It means that an error occurred while v.digit was running. Usually,
> after that error the vector map is not created correctly. That's why
> you get those other warnings below.
> Maybe, someone in the list could help and you if you explain what you
> tried with v.digit.
> > i also tried to use r.to.vect but i got this message
> > r.to.vect
> > WARNING: coor files of vector 'rasttovect at destimap' is larger than it
> > should be (14 bytes excess).
> > WARNING: Cannot display areas, topology not available
> Un saludo,
> Roberto.
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Ti prego di cercare di non inviarmi files .doc, .xls, .ppt, .dwg.
Preferisco formati liberi.
Please try to avoid to send me .doc, .xls, .ppt, .dwg files.
I prefer free formats.
http://it.wikipedia.org/wiki/Formato_aperto
http://en.wikipedia.org/wiki/Open_format
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
Socio fondatore GFOSS "Geospatial Free and Open Source Software" http://www.gfoss.it
e-mail: marchesini at unipg.it
ivan.marchesini at gmail.com
tel: +39(0)755853760
fax (university): +39(0)755853756
fax (home): +39(0)5782830887
jabber: geoivan73 at jabber.org
