[GRASS-user] More QUESTIONS !?
Daniel Victoria daniel.victoria at gmail.com
Mon Nov 5 08:08:19 EST 2007
A long time ago (2003) I asked the same question about linking monitors!
The tread is here:
http://www.nabble.com/-GRASSLIST%3A5609--Linking-Monitors-tf3101985.html#a8608876
John Gillette came up with a nice script to do this using two display
monitors, x0 and x1.
Drawbacks:
1. You must use the old monitors, not a big problem I think
2. You must execute the script every time for each pan or zoom
3. Only one movement por script run (one pan or one zoom)
Maybe there is a way to implement this using the new displays...
To use the old x displays, go to the grass command line and issue:
d.mon start x0
d.mon start x1
This will start the monitors
To select the monitor to use issue:
d.mon select=x0
d.erase erases the monitor
d.rast map=your_map draws on the monitor
Good luck :)
Daniel
The original message by John Gillette follows:
[GRASSLIST:5636] Linking Monitors script Click to flag this post
by John Gillette Feb 21, 2003; 05:50pm ::
try this:
Select and then Erase x1 and then display what ever you want there.
Select x0 and erase and display other info there.
Run this script to either pan or zoom in x0.  After finishing
the pan or zoom x1 will redraw it's contents at the same region
thereby "following" what ever is done in x0.
The disadvantage is that you can only do 1 pan or zoom at a time,
i.e. not interactively.
usage:
script_name z   <- does zoom instead of pan
script_name
zooming and panning in x0.  x0 is selected at exit.
Does this help?
John
#!/bin/sh
d.mon select=x1
monitor1=`d.save -o`
d.mon select=x0
if [ "$1" = "z" ]
 then
   d.zoom
 else
   d.pan
fi
region=`g.region -g`
d.mon select=x1
d.erase
g.region $region
eval "$monitor1"
d.mon select=x0
exit 0
On Nov 5, 2007 7:39 AM, Moritz Lennert <mlennert at club.worldonline.be> wrote:
> On 04/11/07 10:24, Nikos Alexandris wrote:
> > Please excuse me for my "poor" descriptions before.
> > The kinf of "Link" tool:
> > ENVI, and ERDAS as well, provide a "Link" tool with which one can open,
> > side-by-side, images of the same region and while panning, zooming or
> > resizing one of the images, these actions are automatically mirrored to the
> > othe image.
> > Is there an alternative way to replace this method (supporting a visual
> > interpretation with ancillary data)? Would it be very difficult to implement
> > something like that?
> There is no such linking tool in GRASS. However, what you can do (in the
> GIS Manager) is zoom to your desired region in one window, then (in the
> Map Display window)  "Set current region to match display". You can then
> "Zoom to current region" in the other Map Display windows.
> Or if you work with old-style monitors, zoom to desired region in one
> monitor, then 'd.mon select' & 'd.redraw' in the others.
> Moritz
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
