[GRASS-user] ps.map vpoints eps trouble
Frank Broniewski
liste at geo-dienstleistung.de
Mon Nov 12 16:36:44 EST 2007
Hi List
I have a vector layer with points representing sites. I want to use eps
graphics to represent the sites in ps.map. I define the the points layer in
the map description file like below
vpoints sites
color black
fcolor 98 87 78
# symbol basic/circle
eps /home/frank/brassard.svg.eps
rotate 0
masked n
size 1
where epoch = 'Préhistoire' and category = 'Objet isolé'
label Objet isolé
end
but when I run
ps.map -e input=epc/grass\ maps/prehis_cate.txt output=prehis_cate.ps
ps.map exits with a segmentation fault: Segmentation fault (core dumped)
I thought, that maybe the image is not in a good eps format, since I convert
them from svg to eps, but testing the image with
eps 50% 50%
epsfile /home/frank/brassard.svg.eps
scale 3
rotate 0
masked n
end
runs without any problems. So I really don't have a clue why the eps point
representation doesn't work, since there is no error code or something. Any
help is greatly appreciated.
Greetings
Frank
