[GRASS-user] ps.map vpoints eps trouble
Hamish
hamish_nospam at yahoo.com
Mon Nov 12 21:36:40 EST 2007
Frank Broniewski wrote:
> I have a vector layer with points representing sites. I want to use eps
> graphics to represent the sites in ps.map. I define the the points layer in
> the map description file like below
> vpoints sites
> color black
> fcolor 98 87 78
> # symbol basic/circle
> eps /home/frank/brassard.svg.eps
> rotate 0
> masked n
> size 1
> where epoch = 'Préhistoire' and category = 'Objet isolé'
> label Objet isolé
> end
> but when I run
> ps.map -e input=epc/grass\ maps/prehis_cate.txt output=prehis_cate.ps
> ps.map exits with a segmentation fault: Segmentation fault (core dumped)
It works for me using the GRASS logo EPS file,
ps.map out=test.ps << EOF
vpoints archsites
color black
fcolor 98 87 78
eps /usr/local/src/grass/grass63/tools/grasslogo_vector.eps
rotate 0
masked n
size 0.1
label Objet isolé
end
end
EOF
The image is not replicated in vlegend, which is a bug. But you can place that
manually with the EPS instruction.
Is there any other message with the SegFault? e.g. I am aware that a malformed
SQL query causes a segfault, but you get a message about that.
You can set the debug message to high and/or put ps.map in verbose mode to see
more messages.
g.gisenv set="DEBUG=5" # set back to 0 to turn them off
do see see text like this:
epstype=1, pre=/usr/local/src/grass/grass63/tools/grasslogo_vector.eps,
suf=(null)
Scale set to 1 : 102867.
what does that say?
I notice in r_vpoints.c that the EPS suffix (vector.layer[vec].epssuf) is
uninitialized if epstype=1. ? (thus above suf=(null))
> I thought, that maybe the image is not in a good eps format, since I convert
> them from svg to eps, but testing the image with
> eps 50% 50%
> epsfile /home/frank/brassard.svg.eps
> scale 3
> rotate 0
> masked n
> end
> runs without any problems. So I really don't have a clue why the eps point
> representation doesn't work, since there is no error code or something.
they both render with the same eps_draw() function, so the error must be before
that.
tip: if this is still causing problems, you might try a partial string match
with the tricky letters removed
where epoch ~ 'histoire' and category ~ 'Objet isol'
Hamish
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
