[GRASS-user] ps.map vpoints eps trouble
Frank Broniewski
liste at geo-dienstleistung.de
Wed Nov 14 02:06:34 EST 2007
On Wednesday 14 November 2007 03:08:52 Hamish wrote:
> > Frank Broniewski wrote:
> > > I have a vector layer with points representing sites. I want to use eps
> > > graphics to represent the sites in ps.map. I define the the points
> > > layer in
> > > the map description file like below
> > > vpoints sites
> > > eps /home/frank/brassard.svg.eps
> > > end
> > > but when I run
> > > ps.map exits with a segmentation fault: Segmentation fault (core
> > > dumped)
> Hamish:
> > It works for me using the GRASS logo EPS file,
> It worked for me in Debian as I had compiled with the gcc -g debug flag,
> which sets all unint'd memory to null AFAIK.
> > Is there any other message with the SegFault? e.g. I am aware that a
> > malformed SQL query causes a segfault, but you get a message about that.
> I've now fixed that (unrelated) segfault.
> > do see see text like this:
> > epstype=1, pre=/usr/local/src/grass/grass63/tools/grasslogo_vector.eps,
> > suf=(null)
> > Scale set to 1 : 102867.
> > I notice in r_vpoints.c that the EPS suffix (vector.layer[vec].epssuf) is
> > uninitialized if epstype=1. ? (thus above suf=(null))
> I believe the above "suf=(null)" was the problem. It was trying to printf()
> an uninitialized variable. Fixed in CVS and backported to the 6.2 branch.
> The only work around for your current version would to be to put a "$" at
> the end of the eps filename in the ps.map instruction file (but not
> actually on the eps file itself)
> eps /home/frank/brassard.svg.eps$
> and then make a symlink back to the eps file for every category number.
> If you put the "$" but don't make the symlinks you'll get a lot of errors
> telling you what cat/files it wanted to see. The "$" in the eps instruction
> lets you use different .eps files based on cat number, the "$" is replaced
> by the cat number for the eps filename. In the above, "suf=" is everything
> after the $, which for you didn't exist.
> Hamish
> ___________________________________________________________________________
>_________ Be a better sports nut! Let your teams follow you
> with Yahoo Mobile. Try it now.
> http://mobile.yahoo.com/sports;_ylt=At9_qDKvtAbMuh1G1SQtBI7ntAcJ
Hi Hamish,
I replied already yesterday to you, but somehow this email got lost in the
internet universe. I C&P my answer here for your info:
thanks for your help. I downloaded the grass logo from the website because it
wasn't on my harddrive. I prepared a test case with just the point layer in
it and it runs fine too. I added succesively on layer after the other to
track the problem down. By adding a raster map as background I could
reproduce the problem. The whole file looks like below:
paper a3
end
raster dgm
vpoints sites
color black
fcolor 98 87 78
# symbol basic/circle
eps /home/frank/grasslogo_vector.eps
rotate 0
masked n
size 1
where epoch = 'Préhistoire' and category = 'Objet isolé'
label Objet isolé
end
And the last 10 lines or so befor ps.map exits:
D2/5: Vect_cidx_open(): name = sites mapset= PERMANENT
D3/5: dig_cidx_init()
D3/5: dig_read_cidx()
D3/5: Cidx header: file version 5.0 , supported from GRASS version 5.0
D3/5: byte order 0
D3/5: header size 9
D1/5: V1_open_old_nat(): name = sites mapset = PERMANENT
D2/5: Coor header: file version 5.1 , supported from GRASS version 5.1
D2/5: byte order 0
D2/5: header size 14
D2/5: with_z 0
D2/5: coor size 31305
D1/5: get coor
info: /home/frank/grassdata/Luxembourg/PERMANENT/vector/sites/coor
D1/5: Info->size = 31305, Info->mtime = 1194884927
D1/5: coor size in head = 31305, real coor file size= 31305
D2/5: dig_file_load ()
D2/5: requested mode = 2
D2/5: size = 31305
D2/5: file was not loaded to the memory
D1/5: Vect_open_old(): vector opened on level 2
D1/5: Vect_read_dblinks(): map = sites, mapset = PERMANENT
D3/5: Searching for FID column in OGR DB
D1/5: dbln file: /home/frank/grassdata/Luxembourg/PERMANENT/vector/sites/dbln
D4/5: G_getl2: ->1 sites id host=192.168.0.10,dbname=epc pg<-
D1/5: dbln: 1 sites id host=192.168.0.10,dbname=epc pg
D3/5: Field number <1>, name <(null)>
D3/5: Vect_check_dblink: field 1
D1/5: field = 1 name = (null), table = sites, key = id, database =
host=192.168.0.10,dbname=epc, driver = pg
D4/5: G_getl2: -><-
D1/5: Dblinks read
D1/5: Vect_Rewind(): name = sites
D1/5: Vect_close(): name = sites, mapset = PERMANENT, format = 0, level = 2
D1/5: close history file
D1/5: V1_close_nat(): name = sites mapset= PERMANENT
D4/5: G_getl2: -> color black<-
D3/5: G_str_to_color(): str = 'black'
D4/5: G_getl2: -> fcolor 98 87 78<-
D3/5: G_str_to_color(): str = '98 87 78'
D4/5: G_getl2: -># symbol basic/circle<-
D4/5: G_getl2: -> eps /home/frank/grasslogo_vector.eps<-
Segmentation fault (core dumped)
GRASS 6.2.2cvs (Luxembourg):~ >
Just as an info: I run grass 6.2.2cvs on my Ubuntu 7.04 from the repositories.
Frank
