[GRASS-user] MODIS HDF conversion in TIF tool.
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Tue Nov 13 13:19:14 EST 2007
There is a handy tool called HEG with which one can convert HDF files into
.tif. It can be used to create subsets as well. The tool has two modes: a.
stitching/subset modus and b. conversion modus.
It is written in C and Java (for the GUI).
Could it be useful for GRASS? Is there any plan to implement a handy tool to
import MODIS imagery?
FYI:
In my case, trying to convert MODIS Surface Reflectance Daily L2G Global
250m products from HDF to TIF and, at the same time the desired output
(subset) re-projected into the Hellenic Geodetic Reference System 1987, I
bombed into a bug probably (while in stitching/subset modus).
The tool worked also under the conversion modus, since I don't need to
stitch several images together.
The problem now is that whenever I define the parameters for Transverse
Mercator projection (when selected to be the custom projection of the
output) I get an output half-way correct... By that I mean that the output
has following projection information assigned:
Layer Spatial Reference System:
+proj=tmerc +lat_0=0 +lon_0=24 +k=0.999600 +x_0=500000 +y_0=0
+ellps=WGS84 +datum=WGS84 +units=m +no_defs
What I would like to have is
+ellps=GRS80 +towgs84=-199.87,74.79,246.62,0,0,0,0 +units=m +no_defs
View this message in context: http://www.nabble.com/MODIS-HDF-conversion-in-TIF-tool.-tf4799564.html#a13731438
Sent from the Grass - Users mailing list archive at Nabble.com.
