[GRASS-user] MODIS HDF conversion in TIF tool.
Ivan Shmakov
oneingray at gmail.com
Wed Nov 14 07:21:13 EST 2007
>>>>> "NA" == Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de> writes:
>>>>> "IS" == Ivan Shmakov <oneingray at gmail.com> writes:
NA> There is a handy tool called HEG [HDF-EOS To GeoTIFF Conversion
NA> Tool] with which one can convert HDF files into .tif.
NA> Could it be useful for GRASS?
IS> Yes. However, please note that it's not free software (as defined
IS> by, e. g., DFSG [1]) nor open source (as defined by OSD [2].)
NA> Hello Ivan.
NA> Well,
NA> thank you for all of the information.
NA> If it is really not for free, then it does not satisfy my needs.
It's ``for free'' (as in ``free beer'', i. e., free of charge),
but it isn't free software. They aren't providing source code,
for example.
NA> I will have to find an alternative way.
NA> But I didn't find any statement anywhere in the official page about
NA> non-free. I want to complete a work using exclusively free tools
NA> (and if possible open-source as well).
Please make it clear, whether you want free software tools
(``free'' as in ``freedom''), or just ``freeware'' (free of
charge, as in ``free beer''.)
NA> I understand that it is not open-source which is different from
NA> cost-free.
And it is not free software (as in ``freedom'') as well.
NA> Anyway, while contacting with ... I got his response (in which he
NA> offers to give the code if needed). This is why I considered that
NA> it could be interesting for programmers maybe. Here is his reply:
AT> "Nikos,
AT> It looks like that we have a bug in the grid stitching code (I was
AT> able to duplicate your result). We will fix it as soon as possible
AT> (if you really need the grid stitching code please let me
AT> know). Since you are converting only one file, you do not need grid
AT> stitching code. Just use conversion GUI (the one that appears when
AT> you open HEG. Do not select Stitch/Subset from Tool Menu). I tried
AT> the conversion and it worked fine for TM projection. One problem
AT> that I noticed was that in this projection the output file (the
AT> grid) for the product you are using is huge. Although the
AT> conversion produced the output HDF file for me, I was not able to
AT> open it with HDFView because of its size. Once I made another
AT> conversion putting (5000, 5000) meters for the pixel size (about 10
AT> times the actual pixel size in X-Y directions), then the size of
AT> the file was suitable for opening by HDFView. You may not need to
AT> adjust your pixel size since you want tif output.
I don't see anything about the source code here, is it the reply
you've mentioned above?
And, once again, I'd prefer to use some PROJ.4-based converter,
so that, in particular, the choice for the target projection
would be much wider.
IS> [1] http://www.debian.org/social_contract
IS> [2] http://www.opensource.org/docs/osd
