[GRASS-user] import e00? sorry for repeat topic, but...
    Brandon M. Gabler
    bgabler at email.arizona.edu
    Tue Nov 20 13:19:25 EST 2007
Thanks Michael,
I've imported lots of shapefiles by simply selecting the *.shp file
as the data source; does your method produce a different result (such
as transferring metadata, etc. to the GRASS directories)? I had
always understood that for the *.shp vectors, GRASS just needed the
*.shp file.
I'll try the *.hdr import with r.in.gdal as well; that would save a
step and eliminate the need for Arc on my system!
Brandon
_______________________
Brandon M. Gabler
Doctoral Candidate
Department of Anthropology
University of Arizona
Tucson, AZ 85721
Phone: (520) 621-8455
Fax: (520) 621-2088
"Who? When? Whither? are the questions with which the archaeologist
challenges the refuse heaps, scattered potsherds, and broken shafts,
to tell of the builders who came and lived and went their way into
the templed past." -- Edgar Lee Hewett, in Pajarito Plateau and its
Ancient People, 1938
On Nov 20, 2007, at 8:34 AM, Michael Barton wrote:
> Hi Brandon,
> A couple of additional pointers besides exporting as ASCII grids from
> ArcGIS.
> Using r.in.gdal, GRASS can directly read ArcInfo grid files. When
> opening
> them, select the *.HDR file as your data source. No need to export.
> Similarly, v.in.ogr can directly read ArcGIS shape files. Select the
> *directory* in which the shape files live as the data source (no
> "/" on the
> end); select the shape file (omit the ".shp" extension) as the data
> layer.
> Again, no need to export.
> With both, depending on how they were made, you might have to
> override the
> projection info (or rather it's lack) in the ESRI file. But as long
> as you
> know that your ESRI file and GRASS location share the same projection,
> that's OK.
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> Director of Graduate Studies
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
