[GRASS-user] import e00? sorry for repeat topic, but...
Michael Barton
michael.barton at asu.edu
Tue Nov 20 10:34:21 EST 2007
Hi Brandon,
A couple of additional pointers besides exporting as ASCII grids from
ArcGIS.
Using r.in.gdal, GRASS can directly read ArcInfo grid files. When opening
them, select the *.HDR file as your data source. No need to export.
Similarly, v.in.ogr can directly read ArcGIS shape files. Select the
*directory* in which the shape files live as the data source (no "/" on the
end); select the shape file (omit the ".shp" extension) as the data layer.
Again, no need to export.
With both, depending on how they were made, you might have to override the
projection info (or rather it's lack) in the ESRI file. But as long as you
know that your ESRI file and GRASS location share the same projection,
that's OK.
Michael
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
