[GRASS-user] Loop - How To? R.sun manual?
Markus Neteler neteler at fbk.eu
Tue Nov 20 16:05:17 EST 2007
On Tue, Nov 20, 2007 at 05:18:16PM +0100, Roland Pape wrote:
> Hallo,
> >For more efficient batch runs, you might help test r.sun2:
> >  http://thread.gmane.org/gmane.comp.gis.grass.user/20511/focus=20594
> I would like to test r.sun2, but I did not manage to install the addon
> on my Cygwin based system. The "make" command produces the following output:
Please take a look at the README in Addons:
Compilation
The easiest way to compile modules against your GRASS code is
by setting MODULE_TOPDIR on the fly to tell 'make' where to
find the GRASS source code:
  make MODULE_TOPDIR=$HOME/grass63/
(adapt to your /path/to/grass6/ )
Maybe that helps?
> Makefile:9: ../../include/Make/Module.make: No such file or directory
> make: *** No rule to make target `../../include/Make/Module.make'.  Stop.
Markus
