e: [GRASS-user] raster slices to volume
Tomas Lanczos lanczos at t-zones.sk
Tue Nov 20 17:50:03 EST 2007
hanks,
I experimented a lot with this, Your way described below was the easiest
and fastest but the result is not very satisfying for me becasue the
produced "stripes" in the vertical cross section (see the picture). I
also tried to extract points using r.random (3%), and interpolate using
v.vol.rst, but after 12 hours of computing and reaching approx. 20% I
gave it up. What is the best optimalization method for interpolation in
v.vol.rst?
Thank You again
Tomas
Hamish wrote:
 > Tomas Lanczos wrote:
 >> I have contour maps converted to rasters (rock temperatures) in
different depths (-500, -1000, -1500, -2000, -2500, -3000, -4000, -6000
meters below sea level). What is the best way to interpolate them to one
3d raster (volume)?
 > for evenly spaced raster slices first set the 3D region, e.g.
 >   g.region t=-500 b=-6000 tbres=500
 > then use the r.to.rast3 module to make the 3D raster volume map.
 > but you would need to interpolate intermediate levels for missing slices.
 > For -3500 you could use r.series method=average, for 4500,5000,5500
you would
 > have to use r.mapcalc manually.
 > v.vol.rst could be used to interpolate from 3D points, but
RST+contour lines
 > usually is prone to artifact problems do to the uneven spatial
distribution of
 > data points.
 > see also the 3D help page on the wiki site:
 >   http://grass.gdf-hannover.de/wiki/Help_with_3D
 > Hamish
____________________________________________________________________________________
 > Get easy, one-click access to your favorites. Make Yahoo! your homepage.
 > http://www.yahoo.com/r/hs
Type: image/x-portable-pixmap
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20071120/5369f918/temperature-0001.ppm
