[GRASS-user] cvs - error Ubuntu 7.10
Christine Sandmeier
christine.sandmeier at gmx.de
Wed Nov 21 07:46:25 EST 2007
Hello Markus
I had already reinstalled gdal, but that didn't help.
I solved the problem as follows:
libgdal.so.1 was in /usr/local/lib/
I had to add the directory in /etc/ld.so.conf
and rerun "ldconfig".
Now Grass works again.
Thanks for your help.
Christine
-------- Original-Nachricht --------
> Datum: Tue, 20 Nov 2007 22:04:08 +0100
> Von: Markus Neteler <neteler at fbk.eu>
> An: grass-user at lists.osgeo.org
> Betreff: Re: [GRASS-user] cvs - error Ubuntu 7.10
> Hello Christine,
> so you have to fix the GDAL installation first. Without
> that GRASS won't run at all.
> Markus
> On Tue, Nov 20, 2007 at 05:39:35PM +0100, Christine Sandmeier wrote:
> > Hello Markus
> > This is what g.region -p says:
> > g.region: error while loading shared libraries: libgdal.so.1: cannot
> open shared object file: No such file or directory
> > Christine
> > > Datum: Tue, 20 Nov 2007 16:45:30 +0100
> > > On Tue, Nov 20, 2007 at 04:21:15PM +0100, Christine Sandmeier wrote:
> > > > Hello
> > > > I upgraded from Ubuntu 6.06 to 7.10 and since then I got
> > > > child process exited abnormally
> > > > Error in startup script: can't read "parts(w)": no such variable
> > > > while executing
> > > > "set $parts(w) [expr round($parts(w)/$parts(ewres))*$parts(ewres)]"
> > > > (procedure "MapCanvas::zoom_gregion" line 16)
> > > > invoked from within
> > > > "MapCanvas::zoom_gregion $mon"
> > > > (procedure "MapCanvas::create" line 40)
> > > > invoked from within
> > > > "MapCanvas::create"
> > > > (procedure "Gm::startmon" line 11)
> > > > invoked from within
> > > > "Gm::startmon"
> > > > (procedure "Gm::create" line 79)
> > > > invoked from within
> > > > "Gm::create"
> > > > (procedure "main" line 30)
> > > > invoked from within
> > > > "main $argc $argv"
> > > > (file "/usr/local/grass-6.3.cvs/etc/gm/gm.tcl" line 640)
> > > > when I tried to enter location mapset.
> > > This typically indicates a GDAL problem. What does
> > > g.region -p
> > > say?
> > > Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Psssst! Schon vom neuen GMX MultiMessenger gehört?
Der kann`s mit allen: http://www.gmx.net/de/go/multimessenger
