[GRASS-user] cvs - error Ubuntu 7.10
    Markus Neteler
    neteler at fbk.eu
    Tue Nov 20 16:04:08 EST 2007
Hello Christine,
so you have to fix the GDAL installation first. Without
that GRASS won't run at all.
Markus
On Tue, Nov 20, 2007 at 05:39:35PM +0100, Christine Sandmeier wrote:
> Hello Markus
> This is what g.region -p says:
> g.region: error while loading shared libraries: libgdal.so.1: cannot open shared object file: No such file or directory
> Christine
> -------- Original-Nachricht --------
> > Datum: Tue, 20 Nov 2007 16:45:30 +0100
> > An: grass-user at lists.osgeo.org
> > Betreff: Re: [GRASS-user] cvs - error Ubuntu 7.10
> > On Tue, Nov 20, 2007 at 04:21:15PM +0100, Christine Sandmeier wrote:
> > > Hello
> > > I upgraded from Ubuntu 6.06 to 7.10 and since then I got
> > > child process exited abnormally
> > > Error in startup script: can't read "parts(w)": no such variable
> > >     while executing
> > > "set $parts(w) [expr round($parts(w)/$parts(ewres))*$parts(ewres)]"
> > >     (procedure "MapCanvas::zoom_gregion" line 16)
> > >     invoked from within
> > > "MapCanvas::zoom_gregion $mon"
> > >     (procedure "MapCanvas::create" line 40)
> > >     invoked from within
> > > "MapCanvas::create"
> > >     (procedure "Gm::startmon" line 11)
> > >     invoked from within
> > > "Gm::startmon"
> > >     (procedure "Gm::create" line 79)
> > >     invoked from within
> > > "Gm::create"
> > >     (procedure "main" line 30)
> > >     invoked from within
> > > "main $argc $argv"
> > >     (file "/usr/local/grass-6.3.cvs/etc/gm/gm.tcl" line 640)
> > > when I tried to enter location mapset.
> > This typically indicates a GDAL problem. What does
> > g.region -p
> > say?
> > Markus
