[GRASS-user] 3D Geometry and multiple import
Hans-Jörg Keiler hjk at chromgruen.com
Wed Nov 21 05:14:06 EST 2007
aswin indraprastha schrieb:
> Sorry if my question is not quite clear.
> I want to build an campus area in GrassGIS. My primary 3Dmodelling is Sketchup.
> Since there is no detailed geo-referenced map in my case, I begin to
> develop base map by rectifying scanned map from existing vector map.
> It was campus site plan. So now, I have vector map of campus plan  in
> Grass GIS.
> How do I assign each building so that if I import into Grass, they fit
> exactly to their position in vector map (site plan)?Of course,
> SketchUp does not have coordinate system.
> It is important for me because I want to build attribute on each
> building using Postgresql connectivity (spatial database).
> I have not try v.transform yet.
> I had looked your NY map, how you import different 3D shape of
> building into Grass?
> Thank you again for your kind support.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
I also tried to import some Sketchup data into GRASS. I know it is a
mass that those dxf-files contain no xy-values ;-). Unfortunately, the
only software I know solving this problem is ArcGIS, they have a
sketchup-plugin for export and in Sketchup you can export your model as
Esri-multipatch. This way, the data would not loose the xy-values and
database connection (and it would contain texture-information), so each
building on your campus area would fit on its place.
So the solution I know was posted to the mailing-list a few weeks ago:
- get 2D building polygons with heights as attribute column (v.in.ogr)
- get DEM (r.in.gdal)
- get orthophoto (r.in.gdal)
- interpolate dem to highres (I used 2m pixels) with r.surf.rst
- extrude 2D buildings to 3D (v.extrude, give building heights attribute
 column as option and 2m DEM as elevation)
- start nviz with  nviz dem2m vect=buildings3d col=orthophoto
I'm pretty knew to GRASS, so I'm sorry I can't help you much. I thought
about trying with OssimPlanet, but as I learned Ossim requires
gdal1.3.2, which means to deinstall gdal1.4, required for GRASS.... No
way! ;-)
So I also think the only way handling this sketchup-data is to
georeference each building / group of buildings, like it was already said.
Maybe there are any developement plans aiming in that direction (e.g. a
sketchup or another 3D-modelling program plugin)?
Regards,
Hajo
chromgruen Planungs- und Beratungs- GmbH & Co. KG
Alfredstr. 51
D-45130 Essen
Telefon +49(0)201 - 185 355 0
Telefax +49(0)201 - 185 355 1
http://www.chromgruen.com
Geschäftsführer: Dr. Andreas Müller
Sitz der Gesellschaft: Essen
Amtsgericht Essen HR A 8547
UStIDNr.: DE244104036
