[GRASS-user] object-based classification (vs pixel-based)
"Peter Löwe"
peter.loewe at gmx.de
Fri Nov 23 02:49:03 EST 2007
Hello Moritz,
> Hello,
> Some of my colleagues use eCognition for remote sensing data
> classification. After having done so for teaching, we are now looking
> into the possibilities of replacing proprietary with open source
> solutions in research.
> eCognition uses an object-based approach to classification as opposed to
> pixel-based. As they put it in their brochure:
> "The technology examines pixels not in isolation, but in context. It
> builds up a picture iteratively, recognizing groups of pixels as objects.
> Just like the human mind, it uses the color, shape, texture and size of
> objects, as well as their context and relationships to draw the same
> conclusions and inferences that an experienced analyst would draw."
The issue about how to emulate the eCog-approach into GRASS has been around for a while. Here are my two eurocents of knowledge:
eCog consists of several algorithms. First, a segmenting tool (patented...) is used to divide a multispectral image stack into segments. Then, a knowledge-based (fuzzy) merging process gets you to the object-representation.
So to do it with GRASS, we need to have a multispectral segmenting tool plus "the object stuff".
I am not sure if there are any FOSS-segmenting tools in the works that do their job without signature files [medical imaging tools, maybe?].
For the next step, the abstraction from spatial segments to objects, object-oriented grass-friendly environments such as R or CLIPS/CAPE could be used to create a prototype/demonstrator. However, the performance for large data-sets might be significantly below a c/c++ implementation.
Peter
> Is something like this possible in GRASS ?
> Or are there any other open source solutions using this approach ?
> Moritz
Dr. Peter Löwe
<peter.loewe at gmx.de>
GMX FreeMail: 1 GB Postfach, 5 E-Mail-Adressen, 10 Free SMS.
Alle Infos und kostenlose Anmeldung: http://www.gmx.net/de/go/freemail
