AW: Re: [GRASS-user] v.in.ogr doesn't support Postgres Data Type
timestamp
Düster Horst
Horst.Duester at bd.so.ch
Mon Nov 26 04:56:00 EST 2007
Marcus,
Now it works! Thank you very much.
But during testing I'm running into the next problem of schma support.
When I load a layer from schema different to public the schema support
works fine. But when I load a layer residing in public schema with
"public.<table>" v.in.ogr is not able to load this layer. GRASS
responses with:
"Layer 'public.<table>' is not available"
GRASS 6.2-cvs
Best Regards
Horst
Dr. Horst Düster
GIS-Koordinator, Stv. Amtschef
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
SO!GIS Koordination
Rötistrasse 4
CH-4501 Solothurn
Telefon ++41(0)32 627 25 32
Telefax ++41(0)32 627 22 14
mailto:horst.duester at bd.so.ch
http://www.agi.so.ch
-----Ursprüngliche Nachricht-----
Von: Markus Neteler [mailto:neteler at fbk.eu]
Gesendet am: Samstag, 24. November 2007 14:44
An: Düster Horst
Cc: grass-user
Betreff: Re: [GRASS-user] v.in.ogr doesn't support Postgres Data Type
timestamp
Confirmed for 6.2.2. It works in 6.3.x.
The complete test sequence is:
CREATE TABLE test
id serial NOT NULL,
mytime timestamp DEFAULT now(),
text varchar,
wkb_geometry geometry,
CONSTRAINT test_pkey PRIMARY KEY (id)
WITHOUT OIDS;
INSERT INTO test (text, wkb_geometry)
VALUES ('Name',geometryFromText('POLYGON((600000 200000,650000
200000,650000 250000,600000 250000,600000 200000))',-1));
# this was missing in below example:
select AddGeometryColumn ('postgis', 'test', 'geometry', -1, 'GEOMETRY',
2);
# import
v.in.ogr dsn="PG:host=localhost dbname=postgis user=neteler" layer=test
output=test type=boundary,centroid
I have now backported a set of changes:
- PG driver: PG_TYPE_POSTGIS_GEOM and views backported
- v.in.ogr: OFTDate, OFTTime and OFTDateTime backported
It now works:
v.db.select test
cat|id|mytime|text
1|1|2007-11-24 13:03:49|Name
To avoid another 6.2.3 release candidate, please download
http://grass.itc.it/grass62/source/snapshot/
-> grass-6.2.cvs_src_snapshot_2007_11_24.tar.gz
and give it a try. I have created the snapshot again to
include these changes.
Markus
On Fri, Nov 23, 2007 at 02:40:44PM +0100, Düster Horst wrote:
> v.in.ogr v.in.ogr doesn't support Postgres Data Type timestamp.
When you
> try to import PostGIS layer with columns of type timestamp v.in.ogr
> reports the error p.e.:
> table xxx has 4 columns 6 values were supplied
> This example error happens when table xxx hat 2 colums of 6 columns
with
> type timestamp. It seems that v.in.ogr detects the wrong number of
> columns.Isn't is possible to convert timestamp data to character
data?
> Regards
> Horst
> Dr. Horst Duester
> Kanton Solothurn
> Amt fuer Geoinformation
> SO!GIS Koordination
> Roetistrasse 4
> CH-4501 Solothurn
Content-Description: ATT00001
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Markus Neteler <neteler fbk eu> http://mpa.fbk.eu/markus/
FBK-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
New book: http://www.grassbook.org/
-------------- nächster Teil --------------
Ein Dateianhang mit HTML-Daten wurde abgetrennt...
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20071126/93ef0085/attachment-0001.html
