AW: Re: [GRASS-user] v.in.ogr doesn't support Postgres Data Type
timestamp
Markus Neteler
neteler at fbk.eu
Mon Nov 26 09:59:37 EST 2007
Horst,
could you please try 'ogrinfo' on the layer to see
if plain OGR sees it? From looking at the code I
don't see a reason that a 'public' schema should
fail.
Best,
Markus
PS: I still hold 6.2.3 unless this is sorted out.
Düster Horst wrote on 11/26/2007 10:56 AM:
> Marcus,
> Now it works! Thank you very much.
> But during testing I'm running into the next problem of schma support.
> When I load a layer from schema different to public the schema support
> works fine. But when I load a layer residing in public schema with
> "public.<table>" v.in.ogr is not able to load this layer. GRASS
> responses with:
> "Layer 'public.<table>' is not available"
> GRASS 6.2-cvs
> Best Regards
> Horst
> Dr. Horst Düster
> GIS-Koordinator, Stv. Amtschef
> Kanton Solothurn
> Bau- und Justizdepartement
> Amt für Geoinformation
> SO!GIS Koordination
> Rötistrasse 4
> CH-4501 Solothurn
> Telefon ++41(0)32 627 25 32
> Telefax ++41(0)32 627 22 14
> mailto:horst.duester at bd.so.ch
> http://www.agi.so.ch
> -----Ursprüngliche Nachricht-----
> Von: Markus Neteler [mailto:neteler at fbk.eu]
> Gesendet am: Samstag, 24. November 2007 14:44
> An: Düster Horst
> Cc: grass-user
> Betreff: Re: [GRASS-user] v.in.ogr doesn't support Postgres Data Type
> timestamp
> Confirmed for 6.2.2. It works in 6.3.x.
> The complete test sequence is:
> CREATE TABLE test
> id serial NOT NULL,
> mytime timestamp DEFAULT now(),
> text varchar,
> wkb_geometry geometry,
> CONSTRAINT test_pkey PRIMARY KEY (id)
> WITHOUT OIDS;
> INSERT INTO test (text, wkb_geometry)
> VALUES ('Name',geometryFromText('POLYGON((600000 200000,650000
> 200000,650000 250000,600000 250000,600000 200000))',-1));
> # this was missing in below example:
> select AddGeometryColumn ('postgis', 'test', 'geometry', -1,
> 'GEOMETRY', 2);
> # import
> v.in.ogr dsn="PG:host=localhost dbname=postgis user=neteler" layer=test \
> output=test type=boundary,centroid
> I have now backported a set of changes:
> - PG driver: PG_TYPE_POSTGIS_GEOM and views backported
> - v.in.ogr: OFTDate, OFTTime and OFTDateTime backported
> It now works:
> v.db.select test
> cat|id|mytime|text
> 1|1|2007-11-24 13:03:49|Name
> To avoid another 6.2.3 release candidate, please download
> http://grass.itc.it/grass62/source/snapshot/
> -> grass-6.2.cvs_src_snapshot_2007_11_24.tar.gz
> and give it a try. I have created the snapshot again to
> include these changes.
> Markus
> On Fri, Nov 23, 2007 at 02:40:44PM +0100, Düster Horst wrote:
> > v.in.ogr v.in.ogr doesn't support Postgres Data Type timestamp. When you
> > try to import PostGIS layer with columns of type timestamp v.in.ogr
> > reports the error p.e.:
> > table xxx has 4 columns 6 values were supplied
> > This example error happens when table xxx hat 2 colums of 6 columns with
> > type timestamp. It seems that v.in.ogr detects the wrong number of
> > columns.Isn't is possible to convert timestamp data to character data?
> > Regards
> > Horst
> > Dr. Horst Duester
> > Kanton Solothurn
> > Amt fuer Geoinformation
> > SO!GIS Koordination
> > Roetistrasse 4
> > CH-4501 Solothurn
