[GRASS-user] Setting view location in nviz --- problems reloading 3d state
Tom Russo russo at bogodyn.org
Mon Nov 26 10:34:46 EST 2007
On Sun, Nov 25, 2007 at 08:51:38PM -0700, we recorded a bogon-computron collision of the <russo at bogodyn.org> flavor, containing:
> nviz has a "save 3d state" option that looks like it might do the trick, since
> I could simply set my view point by editing a state file by hand.  However
> when I try to reload a 3d state file (even one that's unedited) I get an
> error from nviz.  Attached is the log file.  After reading in the state file
> I *do* get the image from the desired view point, but the position panel is
> messed up --- the position "puck" is no longer available.
> To reproduce:  load an elevation and color map into nviz, choose "Save 3d state"
> then try to read the file back in.
> Anyone seen this before?
I should mention that this is Grass 6.3 from CVS, last updated this weekend and
compiled from sources.  Happens the same way on both FreeBSD 6.3-STABLE and
Ubuntu 7.04.
Tom Russo    KM5VY   SAR502   DM64ux          http://www.swcp.com/~russo/
Tijeras, NM  QRPL#1592 K2#398  SOC#236 AHTB#1 http://kevan.org/brain.cgi?DDTNM
"And, isn't sanity really just a one-trick pony anyway? I mean all you get is
 one trick, rational thinking, but when you're good and crazy, oooh, oooh,
 oooh, the sky is the limit!"  --- The Tick
