[GRASS-user] GRASS for windows script solution
francesco francesco.pirotti at unipd.it
Wed Nov 28 05:01:10 EST 2007
Hello,
For all fearless Wingrass users,  I would like to
share a solution for the following bug  ...."many
shell scripts do not work, even if you enable
correctly msys and include LIB and BIN paths in
the PATH windows variable............" (from the
readme file at the wingrass webpage).
PROBLEM - Long story short, g.mlist gave me
errors because it did not fine "sed" and other
executables, therefore scripts like g.mlist and g.mremove do not work
SOLUTION -
    1 - open the "Init.bat" file located in the
"<grassinstallationdirectory>/grass-6.3.xxx/etc"
... do not use notepad but a better editor that recognizes unix formatted text
    2 - add the line below after
the   ..........if not
"%GRASS_ADDON_PATH%"==...................... line (should be line 29)
           set PATH=/c/msys/1.0/bin;%PATH%
    3 - of course /c/msys/1.0/bin is the path to
the bin directory of msys, if yours is different, adapt.
    4 - start grass and try.
Hope it helps!
Francesco Pirotti
Dept. of Land and Agroforest Systems TESAF
Viale dell'Università 16
35020 Legnaro (PD)
ITALY
Ph.  049-8272710
fax  049-8272686
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20071128/61ac7298/attachment.html
