[GRASS-user] GRASS for windows script solution
francesco francesco.pirotti at unipd.it
Wed Nov 28 06:46:05 EST 2007
Yep, I tried that, but gave me a strange result reading the
C:\xxx\yyy and turning it into /xxx/yyy without the "C" part - I had
to add it using the /c/xxx/yyy syntax directly:  maybe I was doing
something wrong.
Good idea to add it in the grass63.bat file though, to avoid touching
the init.bat.  I will try that!
Thank you Moritz.
Francesco Pirotti
At 11.38 28/11/2007, Moritz Lennert wrote:
>On 28/11/07 11:01, francesco wrote:
>>Hello,
>>For all fearless Wingrass users,  I would like to share a solution
>>for the following bug  ...."many shell scripts do not work, even if
>>you enable correctly msys and include LIB and BIN paths in the PATH
>>windows variable............" (from the readme file at the wingrass webpage).
>>PROBLEM - Long story short, g.mlist gave me errors because it did
>>not fine "sed" and other executables, therefore scripts like
>>g.mlist and g.mremove do not work
>>SOLUTION -
>>    1 - open the "Init.bat" file located in the
>> "<grassinstallationdirectory>/grass-6.3.xxx/*etc*" ... do not use
>> notepad but a better editor that recognizes unix formatted text
>>    2 - add the line below *after* the   ..........if not
>> "%GRASS_ADDON_PATH%"==...................... line (should be line 29)
>>           set PATH=/c/msys/1.0/bin;%PATH%
>>    3 - of course /c/msys/1.0/bin is the path to the bin directory
>> of msys, if yours is different, adapt.
>>    4 - start grass and try.
>As mentioned int he README: "in order for shell scripts to work, you
>will have to add msys' lib and bin directories to your path in the
>grass63.bat file."
>So, no need to fiddle with Init.bat, just add it in grass63.bat:
>set PATH=%PATH+;c:\msys\1.0\bin;c:\msys\1.0\lib
>The information used to be in the .bat file, but we decided to take
>it out in the effort of making wingrass independent of msys. But
>seeing the many reactions on this, I think I will add it again.
>Moritz
