[GRASS-user] GRASS for windows script solution
Moritz Lennert
mlennert at club.worldonline.be
Wed Nov 28 07:14:22 EST 2007
On 28/11/07 12:46, francesco wrote:
> Yep, I tried that, but gave me a strange result reading the C:\xxx\yyy
> and turning it into /xxx/yyy without the "C" part - I had to add it
> using the /c/xxx/yyy syntax directly: maybe I was doing something wrong.
How do run grass ? How do you run your commands.
Could you be more precise about these strange results, i.e. what did you
do exactly and what were the exact messages ?
For me c:\ syntax works perfectly. I can use g.mlist both from the gis.m
menu and from the cmd.exe command line.
Moritz
