[GRASS-user] i.pr: screen does not show map
Moritz Lennert mlennert at club.worldonline.be
Wed Nov 28 09:05:07 EST 2007
On 28/11/07 14:25, Daniel McInerney wrote:
> Hi Moritz,
> What does v.info training give?
 > v.info training
  | Layer:           training
  | Mapset:          user1
  | Database:        /home/mlennert/GRASS/DATA
  | Title:
  | Map scale:       1:1
  | Map format:      native
  | Name of creator: mlennert
  | Organization:
  | Source date:     Thu Nov 22 16:22:31 2007
  |   Type of Map:  vector (level: 2)
  |   Number of points:       0               Number of areas:      14
  |   Number of lines:        0               Number of islands:    14
  |   Number of boundaries:   14              Number of faces:      0
  |   Number of centroids:    14              Number of kernels:    0
  |   Map is 3D:              0
  |   Number of dblinks:      1
  |         Projection: Projection inconnue
  |               N:    -1178.27114746    S:    -2050.34100516
  |               E:     1841.24981384    W:      780.66696671
  |   Digitization threshold: 0
  |   Comments:
> Did
> you use v.digit or v.in.ascii to
> create the layer? I used the latter
> when I was working with it.
I used v.digit.
Moritz
