[GRASS-user] i.pr: screen does not show map
Daniel McInerney
daniel.mcinerney at ucd.ie
Wed Nov 28 09:46:26 EST 2007
I'm under the impression that i.pr.training
requires a point vector map, but I'm not 100%
sure and haven't tested a polygon vector file?
Perhaps, you could use the polygon centroids
to extract your training features or else
digitise a point vector map.
Regards,
Daniel.
Moritz Lennert wrote:
> On 28/11/07 14:25, Daniel McInerney wrote:
>> Hi Moritz,
>> What does v.info training give?
> > v.info training
> | Layer: training |
> | Mapset: user1 |
> | Location: imagery60 |
> | Database: /home/mlennert/GRASS/DATA |
> | Title: |
> | Map scale: 1:1 |
> | Map format: native |
> | Name of creator: mlennert |
> | Organization: |
> | Source date: Thu Nov 22 16:22:31 2007 |
> | Type of Map: vector (level: 2) |
> | Number of points: 0 Number of areas: 14
> | Number of lines: 0 Number of islands: 14
> | Number of boundaries: 14 Number of faces: 0
> | Number of centroids: 14 Number of kernels: 0
> | Map is 3D: 0 |
> | Number of dblinks: 1 |
> | Projection: Projection inconnue |
> | N: -1178.27114746 S: -2050.34100516 |
> | E: 1841.24981384 W: 780.66696671 |
> | Digitization threshold: 0 |
> | Comments: |
>> Did
>> you use v.digit or v.in.ascii to
>> create the layer? I used the latter
>> when I was working with it.
> I used v.digit.
> Moritz
