[GRASS-user] GRASS and ODBC help wanted
    Otto Dassau
    otto.dassau at gmx.de
    Thu Nov 29 12:57:57 EST 2007
Hi Georg,
working with Postgres I would suggest you also use the postgres (pg) driver
instead of ODBC. If you need to use ODBC, because you want to show it in
your lesson, there are some hints in the GRASS wiki:
http://grass.gdf-hannover.de/wiki/Vector_Database_Management#ODBC
regards,
  Otto
On Thu, 29 Nov 2007 18:40:32 +0100
"Georg Lösel (privat)" <georg at de-schorsch.de> wrote:
> Hi all,
> I need some help.
> OS: Debian Etch
> I try to connect GRASS [1] via odbc to my local PostgreSQL database. The
> case is for a training lession about this gis. I connect to Postgres
> because i have no other db.
> The direct contact to the PostgresQL runs without problems.
> I have this
> 1.
> odbc.ini
> [grass_via_odbc]
> Description         = Test to Postgres
> Driver              = PostgreSQL
> Trace               = Yes
> TraceFile           = sql.log
> Database            = grass_nc
> Servername          = localhost
> UserName            = verysecret
> Password            = verysecret
> Port                = 5432
> Protocol            = 8.1
> ReadOnly            = No
> RowVersioning       = No
> ShowSystemTables    = No
> ShowOidColumn       = No
> FakeOidIndex        = No
> ConnSettings        =
> odbc.ini (END)
> 2.
> odbcinst.ini
> [PostgreSQL]
> Description     = PostgreSQL driver for Linux & Win32
> Driver          = /usr/lib/odbc/libodbcpsqlS.so
> Setup           = /usr/lib/odbc/libodbcpsqlS.so
> Threading       = 2
> UsageCount      = 1
> both data located in my local home
> /home/georg/.odbc.ini
> /home/georg/.odbcinst.ini
> Postgres runs
> ok now comes some grass stuff
> set connection
> GRASS 6.2.1 (solothurn):~/solothurn > db.login driver=odbc
> database=grass_via_odbc user=secret password=secret
> WARNING: The password was stored in file.
> check connection
> GRASS 6.2.1 (solothurn):~/solothurn > db.connect -p
> driver:odbc
> database:grass_via_odbc
> schema:(null)
> group:(null)
> and then when i try this
> GRASS 6.2.1 (solothurn):~/solothurn > g.copy
> vect=avdpool_liegen,liegen_odbc1
> COPY [avdpool_liegen at PERMANENT] to current mapset as [liegen_odbc1]
> DBMI-ODBC driver error: SQLConnect():
> [unixODBC][Driver Manager]Driver's SQLAllocHandle on SQL_HANDLE_HENV
> failed (0)
> WARNING: Cannot open database 'grass_via_odbc'
> no database is open
> WARNING: Cannot copy table
> WARNING: Cannot copy avdpool_liegen at PERMANENT to current mapset as
>          liegen_odbc1
> Any idea where the problem is?
> Any hint?
> Thanks in advance
> greeting Georg
