[GRASS-user] temporarily edit tables (dbf) outside of GRASS
Moritz Lennert mlennert at club.worldonline.be
Fri Nov 30 07:46:46 EST 2007
On 30/11/07 11:40, Tim Michelsen wrote:
> Hello,
> I need to do some calculations on my attribute tables.
> What is the corresponding command in GRASS for this?
v.db.addcol
v.db.update
> Is it safe to edit the DBF-table outside of GRASS in another program?
> For instance in OpenOfficeCalc?
> Or even as a CSV with Python, IDL, etc.?
Yes. You can actually create whatever dbf you want, wherever you want as
long as it contains a column with the id's of the objects. Then you can
connnect your vector map to this dbf with v.db.connect.
Moritz
