[GRASS-user] check pixel by pixel
Hamish
hamish_nospam at yahoo.com
Wed Oct 3 03:38:24 EDT 2007
> Andruit:
> > I have several raster maps (aspect, slope, tand_curv etc.).
> > And then I would like to check Pixel by Pixel
> > if slope = steep and aspect = North etc.
> > then
> > "Value of the checked pixel" + 10
> > else
> > Has anybody done this before? Is it possible to combine several
> > raster maps without losing any information?
sure, it is a basic thing for GRASS probably for 20 years. Combining the
maps into one first is a totally unnecessary step.
Jarosław Jasiewicz wrote:
> Thaw what you described has SpatialGridDataFrame in R. Simply you can
> import all raster data to one SGDataFrame and you can do there what you
> need.... It seems, becouse I can't understand for what you need 1 file
> instead of three or for and use mapcalc for that operation. Simply
> seems that mapalgebra (r.mapcalc) it is what you realy need
e.g. r.mapcalc with the spearfish demo dataset:
g.region rast=elevation.dem
# GRASS usually measures aspect in degrees CCW from East
# logic: if(this is true, then do this, otherwise do this)
# "slope", "aspect", and "elevation.dem" are map names.
r.mapcalc "test = if(slope > 10 && (aspect >= 45 && aspect < 135),
elevation.dem, null())"
d.rast aspect
d.rast -o test
you can also use create a MASK map if the r.mapcalc logic starts to get
too confusing, to build up your query bit by bit. see the raster intro
page.
http://grass.ibiblio.org/grass63/manuals/html63_user/rasterintro.html
see also r.mapcalculator for an nice GUI frontend for r.mapcalc.
Hamish
