[GRASS-user] strahler
ivan marchesini marchesini at unipg.it
Wed Oct 3 10:54:09 EDT 2007
Many thanks to all...
the problems are:
1)I wish to use a free/libre solution...
2)v.strahler only produce a text file containing the number of streams
of a defined order... but not a map with attributes concerning stream
order...
3) I know Jgrass, it is a good solution but today I wasn't able to run
it...  I don't know why...  it start but It remain in a frezed situation
("loading workspace, please wait...")
so..
the problem is still not solved...
however, thank you for your help...   :-)
Ivan
Il giorno mer, 03/10/2007 alle 11.52 +0100, Carlos "Guâno" Grohmann ha
scritto:
> Well, there's v.strahler, but I never had much luck with it. I did got
> nice stahler classification using JGrass (http://www.jgrass.org). I
> remember that I couldn' t read GRASS rasters directly (although I
> should), but I managed to get it working by exporting the raster as an
> GRASS ASCII, and then in JGrass, importing and performing the
> hidrologic modeling. The raster layers created by JGRASS were
> immediately available in GRASS.
> Carlos
> On 10/3/07, ivan marchesini <marchesini at unipg.it> wrote:
>         dear users,
>         wich is the best way to classify a stream vector network using
>         the
>         horton strahler method in grass...???
>         thank you very much....
>         Ivan
>         Ti prego di cercare di non inviarmi
>         files .doc, .xls, .ppt, .dwg.
>         Preferisco formati liberi.
>         Please try to avoid to send me  .doc, .xls, .ppt, .dwg files.
>         I prefer free formats.
>         http://it.wikipedia.org/wiki/Formato_aperto
>         http://en.wikipedia.org/wiki/Open_format
>         Ivan Marchesini
>         Department of Civil and Environmental Engineering
>         University of Perugia
>         Via G. Duranti 93/a
>         06125
>         Perugia (Italy)
>         e-mail: marchesini at unipg.it
>                 ivan.marchesini at gmail.com
>         tel: +39(0)755853760
>         fax (university): +39(0)755853756
>         fax (home): +39(0)5782830887
>         jabber: geoivan73 at jabber.org
>         _______________________________________________
>         grassuser mailing list
>         grassuser at grass.itc.it
>         http://grass.itc.it/mailman/listinfo/grassuser
>               Carlos Henrique Grohmann - Guano
>   Visiting Researcher at Kingston University London - UK
>   Geologist M.Sc  - Doctorate Student at IGc-USP - Brazil
> Linux User #89721  - carlos dot grohmann at gmail dot com
> _________________
> "Good morning, doctors. I have taken the liberty of removing Windows
> 95 from my hard drive."
> --The winning entry in a "What were HAL's first words" contest judged
> by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
> Can't stop the signal.
Ti prego di cercare di non inviarmi files .doc, .xls, .ppt, .dwg.
Ivan Marchesini
Via G. Duranti 93/a
06125
Perugia (Italy)
