[GRASS-user] [off-topic] spoke too soon
Glynn Clements
glynn at gclements.plus.com
Thu Oct 4 06:45:24 EDT 2007
Benjamin Ducke wrote:
> All the palettes are available in GMT color format, which is just plain
> ASCII and very similar to GRASS' own colour rule files in the 'cols'
> database elements. The only major difference seems to be three
> additional lines at the end of the file specifying colours for
> foreground, background and no data areas which could simply be
> discarded.
GRASS colour tables have an entry for null, which corresponds to
"no data", but the foreground and background values can be discarded.
> So how about adding an option cpt=filename to r.colors, to set the
> color rules for a raster map from a GMT ASCII file?
That would probably be straightforward.
> The best of these styles could still be hardcoded into r.colors'
> database.
In that case, you might be better off with a script which converts GMT
palettes to files suitable for use by r.colours.
