[GRASS-user] ps.map in scripts?
Carlos "Guâno" Grohmann
carlos.grohmann at gmail.com
Thu Oct 4 12:10:45 EDT 2007
Many thanks!
On 10/4/07, Moritz Lennert <mlennert at club.worldonline.be> wrote:
> On 04/10/07 16:16, Carlos "Guâno" Grohmann wrote:
> > Can I run ps.map non-interactively, like, inside a shell script?
> yes: ps.map in=instructions.file out=map.ps
> Attached an example script which uses the possibility of using
> d.vect.thematic to create a ps.map command file, which is then amended
> before running ps.map on it. (the script allows use of other
> classification schemes than those currently present in d.vect.thematic -
> and yes, I know I promised a C-version of d.vect.thematic...still on my
> ToDo list).
> Moritz
Carlos Henrique Grohmann - Guano
Visiting Researcher at Kingston University London - UK
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows 95 from
my hard drive."
--The winning entry in a "What were HAL's first words" contest judged by
2001: A SPACE ODYSSEY creator Arthur C. Clarke
Can't stop the signal.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20071004/6592a917/attachment.html
