[GRASS-user] Re: r.in.gdal broken on Cygwin
Fri Oct 5 09:21:52 EDT 2007
cheg01 at comcast.net wrote:
> gdb gives the following error on running r.in.gdal:
> >>run
> gdb: unknown target exception 0xc0000135 at 0x7c964ed1
> Program received signal ?, Unknown signal.
> Program exited with code 030000000465.
> You can't do that without a process to debug.
> Internet search indicates that this is a windows error code that it
> cannot find or load required dll files for the program. I have tried
> loading LD_LIBRARY_PATH and PATH with all of the correct locations in
> both cygwin startup and in windows environment variables without
> success.
Use cygcheck, e.g.:
	cygcheck /usr/local/grass-6.2.2/bin/r.in.gdal
This will tell you exactly which DLLs it's looking for.
FWIW, LD_LIBRARY_PATH isn't used on Windows; PATH is used for locating
both executables and DLLs.
> Possible related issue: ldd shows r.in.gdal has a dependence on
> libgrass_gis.6.0.0.dll even though I am running grass 5.4.1.
Are you using a pre-compiled binary of GDAL? If GDAL was built with
GRASS support, it will probably only work with the version of GRASS
for which it was built.
Either find a version of GDAL built for 5.4.1, or a version without
GRASS support, or build it yourself. The Cygwin GDAL package on the
GRASS site doesn't include GRASS support:
	http://grass.itc.it/grass62/binary/mswindows/
	http://grass.itc.it/grass62/binary/mswindows/gdal-1.3.1-1.cygwin.tar.bz2
> I tried
> creating a symlink from grass_gis.dll to grass_gis.6.0.0.dll but that
> did not fix it. It also shows a few other version-specific
> dependencies.
I wouldn't expect this to work; there are incompatible changes between
GRASS 5.x and 6.x.
