[GRASS-user] Re: r.in.gdal broken on Cygwin
cheg01 at comcast.net cheg01 at comcast.net
Thu Oct 4 23:20:15 EDT 2007
More info:
gdb gives the following error on running r.in.gdal:
>>run
gdb: unknown target exception 0xc0000135 at 0x7c964ed1
Program received signal ?, Unknown signal.
Program exited with code 030000000465.
You can't do that without a process to debug.
Internet search indicates that this is a windows error code that it cannot find or load required dll files for the program. I have tried loading LD_LIBRARY_PATH and PATH with all of the correct locations in both cygwin startup and in windows environment variables without success.
Possible related issue: ldd shows r.in.gdal has a dependence on libgrass_gis.6.0.0.dll even though I am running grass 5.4.1. I tried creating a symlink from grass_gis.dll to grass_gis.6.0.0.dll but that did not fix it. It also shows a few other version-specific dependencies.
 -------------- Original message ----------------------
> I am running grass on Windows XP with Cygwin. I cannot get r.in.gdal to do
> anything.  It dies with no output.
> I have installed binaries from grass.itc.it for grass 5.4.1 and grass 6.2.2. and
> for gdal. I have built gdal from source without grass or grasslib support, then
> built both grass versions from source with gdal enabled.  r.out.gdal works but
> r.in.gdal dies silently. Also, gdalinfo works and gdal_translate works.
> Any advice?
