[GRASS-user] d.histogram in 6.3?
Carlos "Guâno" Grohmann
carlos.grohmann at gmail.com
Tue Oct 9 19:59:33 EDT 2007
Interesting, I use both version on my machine for a while and never
had any problem. 6.2 is from ubuntu packages and 6.3 from cvs.
> Check your $PATH and $LD_LIBRARY_PATH settings; also, try running "ldd
> $GISBASE/bin/d.histogram".
GRASS 6.3.cvs (kingston):~ > $PATH
bash: /usr/local/grass-6.3.cvs/bin:/usr/local/grass-6.3.cvs/scripts:/usr/local/gmt42/GMT4.2.0/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:
No such file or directory
GRASS 6.3.cvs (kingston):~ > $LD_LIBRARY_PATH
bash: /usr/local/grass-6.3.cvs/lib:/usr/lib: No such file or directory
GRASS 6.3.cvs (kingston):~ > ldd $GISBASE/bin/d.histogram
linux-gate.so.1 => (0xffffe000)
libgrass_display.so =>
/usr/local/grass-6.3.cvs/lib/libgrass_display.so (0xb7fd2000)
libgrass_gis.so =>
/usr/local/grass-6.3.cvs/lib/libgrass_gis.so (0xb7f82000)
libgrass_datetime.so =>
/usr/local/grass-6.3.cvs/lib/libgrass_datetime.so (0xb7f79000)
libz.so.1 => /usr/lib/libz.so.1 (0xb7f64000)
libgrass_raster.so =>
/usr/local/grass-6.3.cvs/lib/libgrass_raster.so (0xb7f5a000)
libgrass_pngdriver.so =>
/usr/local/grass-6.3.cvs/lib/libgrass_pngdriver.so (0xb7f53000)
libgrass_driver.so =>
/usr/local/grass-6.3.cvs/lib/libgrass_driver.so (0xb7f47000)
libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0xb7ed6000)
libpng12.so.0 => /usr/lib/libpng12.so.0 (0xb7eb3000)
libm.so.6 => /lib/tls/i686/cmov/libm.so.6 (0xb7e75000)
libgrass_psdriver.so =>
/usr/local/grass-6.3.cvs/lib/libgrass_psdriver.so (0xb7e71000)
libc.so.6 => /lib/tls/i686/cmov/libc.so.6 (0xb7d27000)
/lib/ld-linux.so.2 (0xb7fde000)
Seems to me they all point to 6.3?
cheers
carlos
On 10/10/07, Glynn Clements <glynn at gclements.plus.com> wrote:
> "Carlos \"Guâno\" Grohmann" wrote:
> > > > > > Any changes to d.histogram in 6.3 cvs?
> > > > > > just updated and now I can't get a histogram. always got an error msg:
> > > > > > <bgcolor> is not valid
> > > > Yes, what I meant is that this wasn't a "major upgrade" was a clean
> > > > system, fresh OS install, first time I downloaded from CVS in this
> > > > machine.
> > > what were the command line parameters you used?
> > for d.histogram?
> > d.histogram --q map=a17_25 at drumlims style=bar color=0:0:0
> > bgcolor=255:255:255 nsteps=255
> > straight from gis.m, just picked the map and got this:
> > Sorry, <bgcolor> is not a valid parameter
> > if I try in the CLI, without the bgcolor option, I get this:
> > ERROR: [|]: No such color
> > It works fine in 6.2.2..
> This is *definitely* caused by using a version of libgis which is
> incompatible with the d.histogram executable, e.g. using 6.2.2 libgis
> with 6.3-cvs d.histogram or vice-versa.
Carlos Henrique Grohmann - Guano
Visiting Researcher at Kingston University London - UK
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Can't stop the signal.
