[GRASS-user] newbie question - vector/raster processing
Jose Gomez-Dans
jgomezdans at gmail.com
Tue Oct 16 08:57:20 EDT 2007
On 10/16/07, andrew haywood <ahaywood3 at gmail.com> wrote:
> I have then imported the classified vector file into grass. I now would
> like to populate the forest class by intersected the polygons in my new
> vector map with an existing forest class map and take the most common forest
> type from the old map. I was thinking i could rasterise the old forest class
> map and some how count the number of cells for each class within each
> polygon and some how choose the most common class.
This is probably of some help <
http://grass.gdf-hannover.de/wiki/Aggregate_Values>. r.statistics might be
useful, but the wiki entry gives you quite a thorough description. IMHO, it
is far harder than it should be. starspan might also be an option.
Regards,
Jose
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20071016/67a8c34f/attachment.html
