[GRASS-user] azimuth of lines with v.to.db?
    Hamish
    hamish_nospam at yahoo.com
    Thu Oct 18 18:02:36 EDT 2007
Carlos wrote:
> > this doesn't:
> > > echo "UPDATE Lineam_isobase SET ang_rad=atan2(dx,dy)" | db.execute
> > DBMI-DBF driver error:
> > SQL parser error:
> > in statement:
> > Error in db_execute_immediate()
> > ERROR: Error while executing: 'UPDATE Lineam_isobase SET
Martin wrote:
> Use instead of DBF e.g. pg driver, atan2() is not supported by DBF driver.
could you get the values of dx,dy to the shell with (v.)db.select then use awk
to do the math and send the result to db.execute?
Other DBs (SQLite, MySQL, Postgres,..) should support it directly.
Hamish
__________________________________________________
Do You Yahoo!?
Tired of spam?  Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
