[GRASS-user] v.transform
    Dr. Manuel Seeger
    seeger at uni-trier.de
    Tue Oct 23 04:20:13 EDT 2007
Hello all,
I transforming a huge 3D point vector file with v.transform and GCPs. I
want to shift the elevation data but unfortunately the data is set to
the constant value of shift or to 0 if I do not indicate shifting
 I`on an ubuntu 7.10, with grass 6.3 cvs from last week
Can somebody help?
In and output:
v.transform -m input=BAR1_geschnitten at PERMANENT output=BAR1_trans
pointsfile=/home/seeger/Documents/GRASSDATA/Bardenas/BAR1_711_PP_transpose.txt
xshift=0.0 yshift=0.0 zshift=342.12 xscale=1.0 yscale=1.0 zscale=1.0
zrot=0.0 layer=1 --overwrite
New vector map <BAR1_trans> boundary coordinates:
 N: 4681879.885    S: 4681828.345
 E: 624832.091    W: 624761.947
 B: 342.120    T: 342.120
v.transform complete.
                CHECK MAP RESIDUALS
                Current Map                  New Map
 POINT      X coord    Y coord  |        X coord   Y coord    |
residuals
  1.          2.81        21.42 |    624790.81     4681834.33 |         1.08
  2.         18.99        42.30 |    624772.60     4681853.76 |         0.27
  3.         37.57        53.56 |    624764.23     4681874.16 |         0.45
  4.         10.73        -8.52 |    624822.15     4681837.61 |         0.71
  5.          7.04       -25.79 |    624839.56     4681831.14 |         0.17
  6.         -0.04         2.78 |    624811.98     4681828.12 |         1.77
  Number of points: 6
  Residual mean average: 0.921292
Transformation Matrix
| xoff a b |
| yoff d e |
4649814.842972 0.115355 -0.973089
-71809.024515 0.979300 0.150414
_______________________________________________________________________
Dr. Manuel Seeger
Wiss. Assistent 			Scientific Assistant
Physische Geographie 			Dpt. of Physical Geography
FB VI - Geographie/Geowissenschaften 	Geography/Geosciences
Universität Trier			University of Trier
D - 54286 Trier
Tel.:	+49-651-201 4557
Fax:	+49-651-201 3976
Web:	http://www-neu.uni-trier.de/index.php?id=9607
